ISB Torque at Idle
Bad Mileage and IAT - Please Read!
Best brake shoes for 2500?
I am wondering if there is any way to increase the torque that the 24v has at idle. My cousin has a '97 12v with I think it is a 350 TST plate and every time he drives mine he says that it is alot harder not to kill it. He said his can start out in 3rd with no problem where as mine you have to be really easy letting out the clutch. We both have heavier clutches than stock and I have 4. 10s and he has 3. 54s. Mine also had DDIIIs, RV ECM, and PMax2. Is he just not used to mine or has anyone else had the same experience and if so is there any way to fix it???
Thanks,
Keith
You can't expect to pop the clutch at idle and have the truck take off. Your buddy is more familiar with his particular clutch, and is better able to control takeoff at low engine speed. My guess is he'd have a hard time in a little 4-cylinder manual transmission car taking off at all, where you have no torque and have to use a bit more finesse.
If -you- aren't stalling -your- truck when taking off, I wouldn't worry about it! Increasing torque at idle may involve increasing your idle speed.
Greg
Y2K Dodge Cummins QC 2500 SLT Laramie 4x4 Long Bed, 4. 10/Auto, Forest Green/Driftwood, 265x75R16 Michelin LTX, 6 speaker CD, Camper/Tow/Plow Packages, Westin Black Nerfs, Mopar bedliner, Ultra bright diamondplate toolbox, K&N Filtercharger, Autometer Ultralite EGT and Boost gauges in 2-gauge pillar w/tweeter, DD Stage II injectors, boost module, and boost elbow. Yee haw!
http://www.rints.com/hammond for photos!
My idle speed it around 700 or 750 rpm. I thought I had heard somewhere that the 24v where harder not to kill at idle than the 12v.
Thanks,
Keith
Having driven a '93 12v a '96 12v and owning a '98 24v I can tell you that taking off in third with a 12v is a very possible thing to do, but in my 24v The engine bogs down to about 300-400 RPM and then, if it being bogged down quickly, it seems like the computer just gives up, and lets the truck turn off.
The 12v seem to run VERY RPM, sounds like maybe 200RPM, it's just BARELY turning over.
The 24v have a computer that actually controls idle,, if you bog the truck down, the computer fuels the engine (sometimes ALOT) and tries to bring the RPM's back up.
So.
If you were going up a hill, and neither of you touched the gas petal, The 24v ISB would reign triumphantly. If you are in first gear, and in dirt, the 24v truck would actually lose traction before the engine stalled,, compared to the 12v, it would lug lower and lower, till eventually, it turned off. (Unless the dirt was REALLY Lose).
Mi Dos Centavos.
MerrickNJr
1998. 5 Dodge 3500, 2wd
5-Speed, Light Driftwood
STRAIGHT PIPED! :)
3. 55_LSD
A. R. E. Camper w/side pop up windows
Michelin LTX A/T 245/75/16's
Autometer Gaugeworks 3 Gauge A-Pillar Pod
Fuel Pressure (0-15Lbs)
Boost Pressure (0-35Lbs)
EGT Gauge (0-1600*F)
ATS Manifold too!!
My"REAL" Hobby
Cool planes!
I've been hooked on R/C for the past 17 years and have just gottten into the giant scale gas stuff. I'll be entering my first IMAC contest the end of next week.
Are you ever on rconline.com?
later
Mike
99' 2500 SLT QC, 4x4, SWB,NV4500,241HD,Di Pricol 0-60# boost and pyro on the "A" piller,TST flashed ECM, 275hp. injectors, standard Power Edge,Sotty Air, JRE 4" exhaust, BD exhaust brake, Grover air horns, and some other small stuff. Also a Centerforce clutch that is holding on by the hair on it's chiny chin chin... .
