Isbe Comp & controller info:
how to get a working truck
Jake brake part numbers
This is some info from the edge broard that should update you to the in cab controller (EGT,Boost,defuel,adjustable) that will complement the "Comp" isbe.
"Bryce Edge"
We have designed the controller so that it is easily removed if needed. The mount that it will come with will also be easily removed, once again if needed. With the controller you wil be able to turn off your module whenever you'd like, and adjust power levels on the fly. As for the comp leaving codes, it doesn't. We are still in the testing stages of the 03 "comp", but so far all looks well. Hopefully soon we can quote some exact numbers! The controller will probably retail for $200. 00, no numbers on the 03 "comp" yet.
"Bryce EDGE"
In response to your questions:
1&2) To get the readings there will be a thermocoupler supplied to drill and tap. Like regular gauges.
3) Unfortunately the controller isn't available yet. When it does come out it will need to be run with the module.
4) The "comp" module should be released within the next 3 months, hopefully sooner! Prices should be very similar.
It looks like it will be a waiting game for price, availability, power results and only time will tell if this comp will be as legendary as the the last model.
