we have a 2000 Dutch Star Newmar motorhome with a ISC engine Motor # 45957704 330 HP @ 2000 RPM model R534-AA2-001. The unit sits a lot and we found that the last time we tried to start it it wouldn't run. it cranks and wants to run but didn't. we discovered bad fuel and drained and cleaned the fuel tank and filters and replaced the lift pump. we still can't seem to get fuel thru to the ejectors. a new HP pump is about $4000. is there a way we can clean the HP pump without removing it? I feel that it may be clogged with jelled fuel. The enjectors have been cleaned. tried cranking the motor with an enjector disconnected and got very little fuel. any suggestions would be appreciated. The RV is in Arizona and I will be back out there in a month so want to be ready to start working on the fix. Thanks for your help.
