ISL
Arizona Hot-Rod needed
Is there anybody?
Any one heard of the new Cummins ISL Red Head? 370HP 1,200 Ft/lbs. National RV advertise one in their new motor home. Is this a 5. 9 or 8. 3?
Northport,AL. 1999 2500 quad cab, driftwood, 5 speed ISB. Boost and Pyro gauges. Line-x.
Amateur extra W4XH
Just noticed it comes standard with a Jacobs 'jake' brake not exaust brake but true jake brake. Guess that means it isn't a 5. 9.
Amateur extra W4XH
The ISL is a stroked ISC. ISL displacement is around 8. 9 liters. The bore is the same as the ISC, but it has a longer stroke. The ISM is the next step up, which has a displacement of 11 liters. And yes, you can get the jake with the ISL.
2000 Ram 2500 SLT, 2wd Regcab, Driftwood/Agate, 6spd, ETC Diesel. Rickson 19. 5s, Simulators, Michelin 225/70R19. 5 tires, Reunel double break rear bumper, van Aaken CPC, TST Competition PowerMax, RV injectors, HX40-16cm2, 5" exhaust
