ISO OEM brake master cylinder
Limited slip diff
00-02 Brake Proportioning Valve
I have a bad brake master cylinder on my '01 2500 and would like to replace with a new OEM unit. I called several dealers with no luck on a new one, (told me their no longer being manufactured). Wondering if anyone has one stored away they'd be willing to part with. Just need the cylinder.
Thanks
I think both links were for drum brakes, however I think it will work okay. Rear disk brakes started in '01.5, it was a mid year change. My '01 has drums.
The drum brake master cylinder has a 1.250" piston, disk is 1.312" with a larger reservoir. I think the line thread size is the same.
Nick
Thanks everyone. Went and bought a reman chrysler from Napa. Everything is back together and works as it should. I heard an ABS bleed is suggested afterwords but I don't have any lights on and brakes feel fine.
