IssPro Boost Gauge Install
good mechanic/service
Needed: good mechanic
Bought the EV boost guage but the box didn't come with instructions. Looked on the site for some install directions but would like to know if anyone had the IssPro install instructions for the boost gauge. Where do you hook the boost gauge up to the engine? Anyone have a PDF file from IssPro for this install? Seems like it should be really easy just screw in the compression fitting and tubing and you're done, right?
The other end is already ready in my A-Pillar mount.
I drilled and tapped the intake horn for the NPT fitting.
My boost gauge has none of the "jumpiness" that other have found when using the pipe plug to the rear of the fuel filter.
HTH:)
Used the modified intake manifold bolt with the Isspro R7110, Tubing Kit, all from Piers Performance Diesel :) , even talked to the man himself for adviseOo. Can't beat this for an easy install. the picture of the manifold bolt on his site was worth 10,000 words as the saying goes. :)
