Details here: TDR Privileges
My Isspros were packaged separately. I suppose different vehicles/engines may use different types of senders/connections, but the gauge can be used on many different applications. The gauge vendor should be able to help pick the right plumbing kit, thermocouple type, etc.
I have all isspro gauges and they're great. The tach is the best, but the boost (30#) has always given me trouble with the needle sticking @ 0. It was replaced once already and it was admitted to me that it is a known problem.
I use Isspro transmission, EGT, tach, and have a slightly larger Auto-Meter for my boost.
They all work fine with no problems since install.
The Auto-Meter came with all fittings/hose
The Isspro pyro needed the pyro, connection wire etc. extra, the transmission temp came with a wire harness that need to be extended about 3', and the tach ... I can't remeber... I think it needed the connection harness.
I know this reply is a little late, but just wanted to stick my 2cents in. I ordered a set of westach gauges from Geno's garage. (combo egt / boost, and dual temp and the autometer dual pod A-pillar mount. ) Just installed them today. They work great for my app. and they came with all the necessary wires and instructions. If you have any questions feel free to call and ask for Andy or Brandon. Very helpful, I highly recommend them. Oo.
