Does anyone know if there exists a wheel to use on the back of a little Isuzu NPR tilt cab to make it a single rear wheel?
Currently the truck has duals from the factory... but has the 6 lug wheels and I didn't know if they made a 6 lug single heavy duty wheel.
The truck is going to be a line painting rig and the duals make the rear too wide. The tires will be getting into other lines on the pavement, or at least have little room to maneuver.
The weight will be minimal. The painting system weighs 3000 lbs total. So the weight capacity of the single versus the duals will not be an issue so long as the tires are able. And most tires in that size could easily handle that weight.
