Well, most of the 'teething problems' have been ironed out, and there's just a couple nitpicky things that need to be taken care of.
Here's the new dashboard. The only thing that is not operational at this time is the tach.
Guess I cannot complain too much.
The labels got cut off in the picture, but the LED indicators at the bottom are for turn signals, brake warning, hi-beam, wait to start, water in fuel, and overdrive locked out.
Grid heaters, cruise control, and speedometer all essentially function the same as they did when in the original truck (yes that VDO speedo is being driven off of the OEM speed sensor!). Here's a shot of the PCM mounted in its new home next to the CB:
Wide open 4" ehaust. All 4" pipe almost immediately from the turbo back. Only has to go through 3 90s and then out the side. Don't think you can get any less restrictive then that!
Back on its wheels (finally!) and ready for ANOTHER 30 years of service and enjoyment:
Don
Don
