IT,S ALIVE! BUTT?
VE pump
Fuel PIN & Gov Spring only way to adjust idle is with power scew?
Got it running put the star wheel and smoke screw back to stock! Power adjustment ended up at 13 out, runs perfect. earlier I had a total of six runaways. After all this I can tell when it is runnng away and I shut it off. But I had to mess with it. Put star wheel in two, wont start? I shoot a bit of wd40 by the pin when I take the
top off. Does fuel also run in the top of the pump? Is this why it does not want to start. when I played with pin that pushs agianst fuel pin, it seemed notchy at first, so i greased and oilke it till it felt better? Was this a mistake? pump is original 268,000 miles! Rebuild?
Thanx
Ryan
