It Was A Snap!!!!
Engine Temperature
Horton Fan Install
First oil change, not a glich. Thanks to the member posting about the 1/2 drive strap wrench, and the plastic bag around the filter. The whole job was done in about 20 minutes, even tightened up all intercooler clamps (boy were they loose)!!! Next step is to install the gauges. With all I have read about gauge installation, I'm sure that will be easy also. This site and all it's members are the best. Thanks to all!!!! #ad
Y2K01. 5 3500 SLT Quad Cab 4x2, Bright White, Camel Tan Cloth Interior
Y2K Four Winns 170LS Bowrider, 4. 3 V6 Volvo Penta
1999 Suzuki Intruder 800 (for sale) e-mail me if interested, only 1500 mi
Before you dismiss any problems with intercooler connections, take the rubber boots off and check for raised casting ridges on the aluminum parts. These can cause boost leaks, which will rob you of power & economy. #ad
*LOL* Had to edit that post... waaaaaaay too many typos!
[This message has been edited by Evan A. Beck (edited 05-25-2001). ]
I have a 2001. 5 with the spring loaded clamps. They are visually screwed all the way down, with the spring compressed. I have not tried to tighten them, yet. Am I missing something here? It does not appear to me that I could tighten the clamps, even if I tried. Agree with your post Evan, that you could still have leaks with tight clamps.
Shelby
2001. 5 2500 QC LB 4WD, ETH (Built 09-10-00), DEE, 3. 54 gears, Laramie SLT, Camper Special, Trailer Tow, Travel Convenience Group, Power Driver Seat, Alarm System, Remote Keyless Entry, Fog Lamps, Cab Clearance Lamps, HD Transfer Case, Bright White with a Gray Interior. Built 09-15-00, took delivery on 10-06-00, 12310 miles as of 05-01-01. Custom aluminum work body / flat bed. Coming soon: E-Brake and gauges.
Dam now i have to rememger the correct name of the clamps--consent torque--(trade name) the springs should not be mashed down. . (OVER TORQUE'D)!!!!!!!!!!!!!!
Now some one wants to know the correct Inch pound's of torque, do you have a inch lb torque wrench?? IF not bother.
EXample ,a little is good, a lot is better?
speed limit 60 -lets go 120 BETTER result?? can get there faster!!!I could tell you the correct T--but i would have to think hard -or-see the mfg of your clamp,-size-or get out the manual/mfg guide-,and it the week end.
Spring Should NOT Be Bottom'ed Out. . !!!>>!!>
96-3500 SLT EXT. CAB AM/FM/CD-RINO LINER. D-CELERATOR EXH. BRK-RED LINE VAC. OVER HYD BRK CONTROL- AIR BAGS W/HVY DUTY AIR COMP. PUTCO S/STEEL DEEPBOARDS FRONT TO REAR. REESE 20K 5TH WHEEL & GOOSE -REESE 20K HITCH BELOW W/17K RECEVER. CLEAR COATED & SOUND DEADINGING &UNDER COATED 5 SPD/W 4:10 MCHLN'S 235/16'S UNIDEN PC76/WEATHER-WILSON 1000 MAG MOUNT ANT. 4 WHL ANTI LOC BRK SYS.
750,000 miles
