Another note on the door panel.
If you have manual windows, there is a small clip behind the window crank that will need to be removed.
Once you remove the screw behind the door handle pull out the bottom of the panel then lift strait up.
There no anoying plastic rivets like on older vehicles.
Hope this helps.
