Competition Item of interest...
Competition Twins Tee shirts
Competition ?Water Injection?
He must have bought it from Joe Donnelly. Cause nobody else can make 800hp on a single! LMAO!
Seriously, that truck don't run bad.
800 HP on single charger and 370's HUH?
alrighty-then, i like the red paint, goes good with the forest green outside and gray leather.
John,
That must be one of those puller B-1's :-laf. I actually emailed the guy to see if he will tell me he has a dyno sheet for it but nothing back yet :(
Doug
I think its one of those sleeper trucks. - Sorta falls asleep around the 200' mark:D You know around here, we have a ton of those 800hp trucks. Duramax's, Fords and Dodges too. At least thats what the owners say. It must be a Hoosier thing?
Here is his reply to my question on a dyno sheet:
No I do not have a dyno sheet for the 800+ the last dyno I had gotten showed 500+ HP 1000+ foot pounds, that was as high as the dyno went to. Dyno operator said it was well over 600HP+ that was before the additional parts I have added.
Here is the sellers response to the question of what additional parts were added after the dyno of 500 HP.
The 800HP is an estimation from running with other 800HP trucks. After the dyno I put in the new camshaft,bigger delivery valves, changed from Holset HX50 to the B-1...
Here's what he told me
"What pulling events has this truck won? Will you compile a list for me. Also can you give a ballpark figure of the reserve?"
Reserve is $18,000. 00 ... you can call me about the pulling events! 1st place-Rochester,Camden,Warsaw, Plymouth (within last 3 years)-2nd place - Rochester-bi county(due to loosing charge air hose in pull off), Winamac, top 10 at Diesel Extravaganza out of 65.
CumminFast said:
800hp my ***!! maybe a shade above 500... looks like they cut a good bit off the pistons.
yeah, some pretty excessive timing too! check out those pics of it idleing.
