Truck quit on way home tonight. Jumpered aux. fuel boost pump to get it home (no lift pump noise) Can't find any blown fuses. Put A/C clutch relay in place of fuel pump relay and lift pumps work. Haven't seen anything on this problem. Is there a fuse or overheat breaker in the system? Has anyone had a similar problem? If so, what was the cause? and finally did a relay replacement solve the problem?
Thanks, Denny
Thanks, Denny
