I am running a Jacobs exhaust brake off a 2001 24v on my 98 12v... I also had 60lbs exhaust springs installed... It works flawlessly... can't imagine anything working 10x better... if something did work 10x better, it would launch you through the front windshied...
Because the Jacobs brake off the 24v I got, was wired into the PCM (for throttle on/off), which I didn't have on the 12v... . I used a PacBrake microswitch that mounts under throttle pedal for on/off, and a stick shift mounted BD push-pull type switch for the master on/off. I didn't actually buy the BD switch, as they want a ton of money... I bought an identical switch from a truck store, designed to control a two speed rearend.
