Jacobs Exhaust Brake
Anyone out there with a TST PMCR for sale?
Injectors for towing
STEVEBROOKS
I'm interested in adding a Jacobs Exhaust Brake to my truck, and would like to get some inputs as to the best place to buy one. If you've done this, please tell me:
A. Where you got it (include phone number and/or web site if known)
B. Its price
C. Any installation advice (above what's in the instructions)
Many thanks!
Steve
I bought it here: http://www.klenger.net/dodge/general-reference/mechanicsville-dodge.html
Installation advice: It's a PITA to install, especially the vacuum pump. The serpitine belt is really a pain, but I don't do this stuff very often. Pay attention to how the belt is routed before you remove it. On my 04. 5, there is a small tube with some wires in it that goes from the bottom of the radiator to the center of the fan hub. I don't know if the 03's have this, but I assume they do. When I was putting the new belt on, it appeared that the tube was preventing the belt from going on, but I knew it had to work because I had just removed the old one. I think I spent about 10 hours installing mine, but the end result was very good. I tend to take longer than most people when installing stuff like this because I am very fussy about workmanship. I fugure that I save about $500 by buying the brake mail order and installing it myself. For 10 hours of work, that's $50 / hour.
Good luck and happy towing.
Don't forget to put the old belt under the back seat. If (God forbid) your belt ever breaks you will have a spare. There is a diagram on the cross piece in front of the radiator to remind you how it goes on. You will have to by-pass the vacuum pump pully (losing your exhaust brake) but you will be able to get home.
Fireman
Fireman: Good suggestion. I plan to keep mine in a box with spare oil filter, fuel filter, oil, ...
My father in law was telling me that he had to change the belt on his truck in -40* weather in Alaska. I said I would have called a tow truck.
Does the Jacobs Exhaust Brake come as a complete kit with the vacuum pump and the hardware to install in your truck?
Robert
I've got a new 2004 3500 Quad 4x4 Long Bed automatic ordered. Should be here toward the end of June. Should I wait on exhaust brake installation?
Ted
After installing the e-brake, can you buy a replacement serpentine belt at an auto parts store or do you have to go to the dealer or Cummins?
