Engine/Transmission (1998.5 - 2002) Jammer 3s
Engine/Transmission (1998.5 - 2002) Little Less Smoke?
Engine/Transmission (1994 - 1998) Adjusting idle
I have a set of edge jammer 3 nozzles that I bought and never installed because I heard after I bought them they were crap. I have a friend that wants to run them in his truck are they really that bad? I have a pop tester at work so its no problem installing them. Also out of curiousity if you are runnning jammer nozzles what pressure did you set them at? I know they are suppose to be set at 310 BAR (IIRC) just curious if you tried different pressures.
Bought mine from Source Automotive. Presumably they were match set and tested. Haven't had any problems with them. Truck still runs smooth. Better than the DD2s that I had in.
How many miles do you have on them? Do you tow alot? Thanks
OK, maybe I am a bad example. Less than 3k miles, and no towing. My recent power jump (twins, injectors... ) were done in February.
However, the Jammer injectors have been on the market for a long time. Typically if they are a bad product, they don't last long, and I have never heard anything bad about them. IMO better than your "Extruded/Honed" injectors which are factory tips bored out.
Iv'e been running jammer 3's for about 50k. I bought just the tips from Source Automotive also. I changed them out using my stock injector bodys.
I didn't have axces to pop-tester, so I took my chances and not one problem.
Maybe I got lucky but I think there great!!!
I do some towing but, not all the time
