Just an update on the exhaust drone. Some trucks have it and some don't. Some with DD, BD, Pinacle and Banks have experienced it. Some with Jerry's have had sucess with the resonator and some haven't. some with the drone have moved the muffler forward with success and some haven't.
Some with stock exhaust have removed the stock muffler and/ or resonator and experienced it. If you dont have it, great: but don't assume that just because you put a resonator on at the time of system install that you cured/ eliminated the drone: You might not have had it to begin with as most trucks don't.
Mine was cured by just replacing the Pinacle muffler with a Donaldson in the same location. My truck is quieter towing at all rpm than when not towing. A couple of other TDR members in the area have replaced their mufflers ( several different exhaust vendors ) with the Donaldson with the same results I have experienced.
What ever works for you is best for you, there are many fixes, it is just a matter of finding the one that works on your truck.
Good luck
"Devildog"
" When I called DD about the drone they said " what drone" no one else complained"
That is what Jerry said when I called him in the early spring of 2k.
Devildog, the Donaldson souds just like Jerry's muffler under load but with out the drone and as quiet as stock at idle.
