Just picked up a Jayco 341RLQS 5er. It is built on the Designer frame and has shock mounts on the axle and frame, but no shocks installed.
Anybody able to give me a part number for the shocks to go on this unit? The Designer 34RLQS chassis is identical.
The shock mounts accept the threaded piston type on both ends (like the top end of the front shocks on our CTDs). Monroe makes a kit but requires holes drilled in the frame, and the lower end attached to the spring pack u bolts. Since the mounting pads are already there I'm looking for a bolt-in unit.
TIA
TIA
