Jeep is a 79 CJ5, 304, 3 speed in good condition. I need help is diagnosing the popping binding noise from (I think) the transfer case. Only happens in 4wheel drive, low and hi range.
It sounds almost like the front drive shaft rear u-joint is hitting something, or possibility a gear or chain binding and popping. Again only when transfer case is in 4wh. drive mode, front hubs locked in or not, no difference.
All U-joints and slip joint yolks appear good and are freshly lubed, not that they couldn't be at fault since I haven't pulled and really checked yet.
Only happens when I apply moderate to heavy throttle in 1st or 2nd gear, high torque situations. It sounds like if I did it for more than a couple of seconds something is gonna break. No odd noise in hi gear 4hi cruse mode or any other gear in a no load situation.
My fear is I'm gonna need to pull the transfer case, just don't want to go there if not the problem.
Any help is appricated.
Thanks,
RJR
Thanks,
RJR
