Somebody say rockcrawling?
Probably won't make it to the Rubicon this summer, it's a bit of a drive from Denver.
Just got back from Moab (Easter Jeep Safari). Ran a few new (to me) trails this year, including Rusty Nail, Lower Helldorado, and Upper Helldorado.
The spec list is kind of long, but it's already typed up, so:
'83 Blazer
Front Axle: Dana 60, rebuilt, 4. 56s, Detroit.
Rear Axle: 3/4 ton 14 bolt, 4. 56s, Detroit, custom disks.
Steering: Crossover using 2wd box, Avalanche Engineering steering arm, Scout pitman arm, heim joints and 1-1/4" OD, . 287" wall DOM tubing, 3 stabilizers, frame reinforcement plate and ORD brace. Heim joint/tubing tie rod, reinforced w/ angle iron.
Front Suspension: 4" Pro Comp front springs, Homemade shackles (1/2" longer that stock), single Pro Comp shocks, ~3” lift.
Rear Suspension: Stock springs w/factory overloads, shackle flip using OE stock hangers, single Pro Comp shocks, ~3” lift.
Brakes: Hydroboost, 1 ton master cylinder, braided steel extended lines, adjustable proportioning valve.
Tires:
Street: 35x12. 50R15 BFG Muds, bald, on 15x10 chrome mods w/4-1/8" backspacing.
Trail: 15x39. 5-15 TSL Swampers on 15x10 American Racing wagon wheels w/4-1/8" backspacing. I think the bead locks are MRT, they were put on by Tru-Design wheel.
Motor: Originally 6. 2 Diesel, replaced w/'87 TBI 350, MSD 6AL, full length headers, single big block Flowmaster.
Trans: Stock 700R4, rebuilt, slips bad in 2nd.
T-case: Stock 208.
Driveshafts: Stock, conversion joint in rear.
Winch: Warn 8274 in old Warn winch mount/brush guard.
Dual batteries, isolated, one starting & one deep cycle.
Top:
Summer: Kayline, older snap-style.
Winter: Hard Top.
Body: Lots of Sawzalling, grinding, cracks, and dents, w/a 5’ wide red bow tie on the hood.
Pete
'97 2500 CC 4X4 5spd Sport
'83 K5 Blazer 350 TBI (ex 6. 2), 39. 5 TSLs, 3" lift, Dana 60/GM 14 blt, Detroits
[This message has been edited by pcorssmit (edited 05-08-2001). ]
