Jet A
BOMBed a PSD
Had a Torque-out w/ a Powerstroke
Was given 300+ gallons of Jet A removed from an aircraft #ad
Can anyone reccomend a good lubrication additive? I intend on using this fuel in my Cummins powered binder.
1997 2500 SLT 4X4,5 spd,3. 54's,Pacbrake,Rancho 9000's,Centerforce,K&N,Isspro,BD 300 HP pump, Jardine 4", 370's and 16cm housing.
[This message has been edited by R. ebel (edited 05-08-2001). ]
I've always felt that Howe's and Marvel Mystery provide more lube than the other popular brands. You could also mix the A 25% to 75% # 2. Either way you won't get as much power or fuel economy as you would with straight #2.
Since JetA is very dry I would use Stanadyne Performance formula. I have used it for about 125,000 miles on #2 and I'm happy with it.
1993 250 4X2 - Banks Power Pack, BD Power Injectors, K&N Air Filter, 6 gauges and tweaked pump. 27lbs boost unloaded.
Horton fan & NV4500 5 speed.
I also was told by a very knowledgable man about stadyne diesel libricator, he said it was made for the military so they could run any(even gasoline) fuel in their equipment to make it home. Its supposed to be good stuff.
Jet A is a very dry fuel. I would use it for a winter blend,maybe 25%. But for summer it may be a little to hard on injectors even with staydyne.
95 Dodge 2500 Luverne grill guard,headache rack,running boards and Amzoiled. Soon to be mildly bombed. 84 Dodge d-150, 318 Hooker headers,Edelbrok intake,mallory ignition,Carter Afb,Accel coil,and Custom dual exhaust. Boat,fifthwheel,motorcycles,and shop. 72000 as of 3/1/01,not even broke in yet. Old Dodge 126000 miles and running better than new.
