You might try some out board motor oil TCW3 1oz per gal. If it was me I would go with 2oz to start with to be on the safe side. I thank jet fuel has less oil . Try here
www.mopar1973man.com
Like 4-stroke lube oil, 2-stroke oil has lots of additives. The only oil I would use in fuel would be straight, base oil with no additives, and then only if I absolutely had to.
Jet fuel has no additives. Remember that spate of failed pumps back when ULSD was first on the market? Refiners could not include additives in the fuel they sent down the pipelines, because they use the same pipes for jet fuel which cannot have additives. And some distributors were not adding adequate amounts of lubricity if they were adding any.
On the frivolous side, if you really want to use the JetA in the car,
- mix one part to 3-4 parts #2 (i. e. , 3 gal. JetA to 12-15 gal. #2),
- double-dose the whole tank with a commercial lubricity enhancer,
- sacrifice a few rodents to your mouser,
- cross your fingers,
- pray to your god, whether you conceive him as Hairy Thunderer, Cosmic Muffin, or some other entity, and
- (optional) play Johnny Mathis' song, "Chances Are", repeatedly on the VW's stereo.
As old as it is, you probably owe the car more than it owes you, so let it pass in a blaze of glory: full tank of JetA, double-dosed with lubricity enhancer. Also make a few passes at the local drag strip (before on #2 and after on JetA) and post the results here; it'd be interesting to know the actual power and performance difference between JetA and #2.
Click here to address the serious aspect. JetA is akin to, but different from, #1 oil (kerosene). It has a lot of sulphur. So you get to decide if mixing it the same as you would mix kero in your fuel is 'safe' for your 23-year-old car. Were it mine, I'd run a 50-50 mix with a double-dose of lubricity enhancer and not think twice about it.
