i am about to buy a new john deere 5225 4wd with a 55 hp 3. 0 5cylinder. it's a 5030t power tech read about it here
http://www.deere.com/en_US/rg/productsequipment/productcatalog/ind/t2_pt/5030/series/index.html
my question is 55hp out if this 3. 0 l is conservative the engine is rated over 99hp in generator applications can this engine be turned up?
one note the injector pump is mounted inside the block and so are the injector lines?? how do you bleed lines once air locked?? anyone know about this engine? notice how the turbo blows directly into the valve cover???
