JRE Fuel system = Lower ET and Higher MPH
rust remover
Vacuum ports for air horns
JRE has finally been able to test our fuel system for Power results.
As you Know we have more than a few 1/4 mile runs under our belt and our 98 24 valve truck is very repeatable and consistant, before the fuel system our best ET and MPH were 14. 45 ET and 90 mph.
I suspected that there was POWER in our fuel system as well as the COOLING and LUBRICATION benefits.
On Sat. Sept. 30th we installed the fuel system and on Oct. 1st we dorve 180 miles to the race track in NH. and were able to run 14. 32 ET and 91. 24 MPH, consistantly, this equates in to around 35 hp.
I will figure it out exactly when I get to work.
Ted Jannetty
Ted Jannetty, Owner President Jannetty Racing Enterprises Inc.
97 3500 4x4 club cab 5spd. RED, JRE stage 3 power kit, JRE 4" exhaust
JRE 1/2 inch fuel system, Bosch 300 hp injectors, Prime loc,
Cummins chrome kit, US Gear 20% over drive, 3. 54 posi, Autometer
Ultralite 50lb. boost, and Pyrometer, BD exhaust brake.
99 Ski-Doo 800 Formula III
99 Honda Forman 450 ES
2001 Ski-Doo MXZ 800 X
2000 Transam Ram Air WS6
[This message has been edited by Ted Jannetty (edited 10-02-2000). ]
Ted,
Need details on your new fuel system. What's it consist of, price etc. ?
Terry Tucker, Terre Haute, Indiana, 99 Quadcab, 5 sp,TST New Powermax2, RV injectors, Scotty's K&N setup, Ted J's complete 4 in exhaust(No muffler or resonator), 4 Rancho 9000 Shocks, G-Tech, BD exhaust brake, Mag-Hytec diff cover, PIAA driving/fog lights, Putnam Firehawk combo 5th wheel/Gooseneck hitch, Amsoil dual remote oil filters, All Amsoil fluids, Weston one piece Brush Guard, Linex liner. Dyno results: 334 hp, 859 ft lbs
I've been following your half inch fuel line thread since your original post quite a while ago. I was also checking it out on your site last week. I was hoping you would be coming back with some results after the install. Sounds as if it has made a difference. Don't tell me I have to put one of these on my Christmas list also?
Ted - were all conditions equal between the runs? Same temp, humidity, track, driver etc, etc?
What were the before/after fuel pressures downstream of the transfer/lift pump?
Brian
Yes all conditions were equal as well as elevation.
The kit consists of everything you need to have a true 1/2" line from inside the tank to the lift pump, you can see a picture at www.jannettyracing.com
Installation takes about 4-5 hrs.
Call for Pricing. 203-753-7223
Ted Jannetty
