Juice and smoke
12v head vs 24v head vs 24vcr head
fuel pressure acting funny
Kvic
O. k. so I installed the Juice w/att, on level 5,5 all I get is a little puff of smoke, then it clears up. Is this normal, as I read about guys with the same set up sending billowing clouds out. Does this mean, that my engine is actuall using all of the fuel added, or do you think something is not right? By the way no codes have been thrown.
Thanks
Kris
I'm in the same boat, I will sometimes put mine on 4/5 and this day it will blow all kinds of smoke and that day, it will only puff like he said, what gives here??? :confused:
you need to adjust you low boost fueling. go int you menu on the additude and pick jucie con and the pick adjust low boost fueling on level 5 in level 5 then it will blow some smoke
Mine only blows smoke when I'm push the pedal at low speed. I'm assuming this is because the turbo takes longer to spool up at low speed. At high speed, it's already spooled up. I do get some smoke if I put it to the floor on the highway.
I have the same thing with mine to. In theory we should be happy there is no smoke because are trucks are so dam good they burn all the fuel we can feed them. If you guys are like me though sometimes you just wanna blow black, I could care less about how fast I can take off I just want to get in front of that prick in a Mercedes and blow a cloud of black ALL over his 60k dollar car. :-laf I think if you wanna get some more black you will have to get injectors and a little better lift pump. Hell if worse comes to worse take your turbo off, you will get TONS of black then. (don't really do that!) :D
Mine blows a lot less black smoke in the winter time due to the denser air. On a hot summers day it'll lay down the coal :D:D:D
another way to get it to smoke is take off somewhat normal then mash the pedal it will dump fuel in before turbo actually spools up wah lah black smoke like you would not believe. waste of fuel but fun :p
Mine blows more smoke on LBF 3 than it does on 5. That's true for all power levels. Doesn't make any sense, but I don't care, I just leave it on LBF 3. ;)
Biodiesel kills the smoke. Even B2 forces me to try to blow smoke. B20 is embarrassing, almost nothing... relatively.
