Engine/Transmission (1998.5 - 2002) Juice with Attitude for 98-02 24V?
Has anyone heard anything about this? I went into a local performance auto store about a month ago to price out an edge comp and was shown a booklet from Edge saying they had the Juice with Attitude available for 98. 5-02 24 vavles. I was even given a price quote with part # for this.
I decided to look around some more but haven't been able to find this anywhere. Edge's website doesn't even have anything on this. So I went back the local shop to order one, only now they say none of their suppliers stock it.
My dad has this chip and monitor in his 04 duramax and I'd really like to get one. I was told it might not have been released yet, if it is in fact real. I'm just wondering why a company would have literature out for at least a month, for a product you can't get.
Now are the 2 big questions. Which will be the preferred setup, juice, or comp? Also when will a Hot Juice variant be available?
beta testing
Hello Gents,
I have been picked of a lucky 20 in the Country to beta test the Edge Juice With attitude for the 98. 5-02 dodge. Very cool setup
Anyways you have to tap the pump wire of course (No Way around this). It also Monitors the fuel pressure at the Lift Pump. (All Hardware to Tap The Fuel System comes with the kit). You also have to Tap your transmission pan for either a Auto/Man. . I have a 5 speed so you have to take off your pto cover and NPT tap it. As far as the Comp vs. Juice it's the same Power. I had A Drag comp box on before, Edge told me since im beta testing they will upgrade the juice to a HOT juice once they get the program Figured out in the next week or two. I'm sure when the Juice is Availble to the public the hot version will be ready. Hope this helps
Tibbittts - Look how long Edge advertised the A2 Before it came out it was well over 6 months. It will be out soon enough
Patrick
a lot of the other guys talked about the SMARTY it is in the research and development forums . sounds pretty tasty , check it out!
Juice/ Attitude
I installed the Juice/Attitude on a beta testers truck last week. It was an 02 Dodge 6 speed. Looks like this is going to be an awesome product. Yes you do have to tap the wire on the injection pump. But, now it comes with the posi-lock type not the POS scotch lock also when complete you can check to make sure the contact is working on this wire by taking ot the end of the juice and watching for lights to flash. The fuel pressure is a tapped banjo bolt with the sensor screwing onto the bolt. Also comes with a turbo shut down timer like on the Ford 6. 0L Platnum.
