check your thermostats ...
1 minute job ...
been smelling antifreeze so i figured might as well do the 'stat and pump as long as i'm doin' the heater core ...
as posted by someone else recently the stock stat is pure crap ...
mine has lost 80% of the rubberized coating on the internal part of the 'stat
not the o-ring but the part that actually moves up and down ...
got a chunk of rubber the size of a quarter somewhere in my system now ...
3 8mm bolts ... torque specs @ 18 ft/lbs per manual ... napa part is MUCH higher quality part # 375-190
5 minutes may save you big ...
1 minute job ...
