on the 48re auto there is a line pressure screw on the valve body, how much of a turn counter clock wise does it take to add 10 psi, the reason is that we got wades transmission in and all was well, until barry @ nadp called and says that you have a (special ) valve body and it is not adjusted. he asked us to turn it 2 turns counterclock wise to get in the ball park, well that was done and all buttoned up and shifts are dead on 1-2,@ 3100rpm but 3rd is waiting until 3600rpm to shift into lock up(4th). and all the shifts are notably soft. this leads me to belive that i need more line pressure and would like to know how much is needed for appox 10 psi increments. wont get to fix it until tuesday or so, got to drain all the fluid ( amsoil )and drop the pan---- for a simple adjustment, we are shooting for 90+psi @ idle and at least 170 psi 2 wot.
other than that the truck runs great, we replaced the injectors and new push tubes went in and we also got to put a duel feed rail line on as well----lots of cool stuff. hopefully we will be busting some good times at the track shortly Oo.
