Just Put The 10 Plate In And Now The Bottom End Power Is Gone . This Would Be Great If I Still Had My Stock Clutch . I Set The Governor Arm To Hit The Tip . I Know If I Get The Arm Up On The Ramp Some That This Should Help Me Get My Balls Back . Has Any One Counted The Turns Out On The Governor Screw Needed To Get It Some Were Near The Stock Clutch Slipping Range . I'm Sure Most Every Body Has Lost Track But If This Could Save Me A Couple Less Trips To That Back Plate Off & On. Since Its Such A Big Pita To Get At . It Would Be A Big Help Thanks . mjs
