just dont know what to do....some info
Need Cummins Article
TST@TS Performance’s Power Play MP-8 Stack help
well i am new here and am glad that i joined..... hello everyone
now..... i have a 1ton dodge dually. . with a 6 speed and ho,,,,20003. i dont know what to do... ihave contacted banks and they said put astinger system on... . or should i put bigger injectors in... reason is because i pull a rv that weighs... 15,000lbs... . but as stock does well... i just want alittle more hp... torque... that wont void my warranty... so... any one have ideas which way i should go... . hope to hear from everyone about this
Moved this over here for better exposure. I'd suggest to start by using the search function on the board as you will found countless posts about how to go about making more horsepower. If you are towing that heavy and plan to add power mod's you really need gauges, at least a pyrometer. A boost gauge is considered mandatory by most as well. As to your warranty any aftermarket power adder will cause you to run the risk of a voided warranty if the dealer feels it was the cause of a failure. There has been a lot of discussion about who is responsible for what when modifications are added and then the truck breaks. The Mag-moss law says the dealer must prove your modification caused the failure, but good luck changing DC's mind if they void your warranty, in short you most likely will have to hire an attorney to fight it. Others are willing to fix whatever breaks themselves and are not concerned about a warranty. So enjoy your new truck, enjoy the forum, you will learn a lot here. I know I have
Jay
Banks makes exactly what they say... ... for a price. I see this is your first post... Welcome. Do some searching. There are people with trucks like yours running 12's in the quarter mile. I'm sure pulling like you do will be a Cinch as well. .
Josh
