Just got in from doing my 15K service (severe cycle)
I had a good therapy session in the driveway today and everything went well
. I didn't change out the rear oils since I don't think I have enough to refill (amzoil 2000 75W90) and, although the cover gaskets are reusable(?) I want some hanging on the hook just in case.
There are two items I wanted to give a heads up about to anyone planning to do a similar service to their truck that I noticed on mine.
1) I rotated the tires and the wheels were seized onto the hubs and took a lot of force to break 'em loose. I cleaned the wheels and hubs with a wire brush and applied a light coat of anti-seize compound.
2) My truck has a rubber mounted balancing ring at the front of the rear driveshaft. This ring is isolated with rubber, similar to a harmonic balancer on an engine. I believe the rubber is breaking down since the ring is easily deflected (I don't recall this in the past). I will be monitoring this and have "timed" the ring to the shaft with a permanent marker.
I apologize in advance if this info has already been covered.
