Vulcan now has the brackets, I got mine and installed the DDRP on the frame rail on Wednesday, probably one of the first!
You have to drill four holes in the frame and then use self threading bolts.
More or less bolted up.
The new compression washers I had were too large of OD to fit into the inlet/outlet counter bores on the DDRP, had to use the old ones.
Because I had replaced ALL of the fuel lines forward of the tank pickup previously, I needed to replace the line from the new pump up to the stock filter location, was about four inches too short. That could of been avoided by leaving a little slack in the lines when I originally did the OEM pump relocation to the frame rail.
Much, much quieter than the stock pump, even with the stock pump using rubber isolators. The DDRP has no rubber isolation, solid bolted to the bracket and the bracket is solid bolted to the frame rail.
So far good fuel pressure measured at the VP44. Runs about 15 PSI +/- 1 PSI most of the time, although I have seen spikes way higher and saw 7 PSI once for a few seconds. I have a SPA digital FP gauge that captures peaks and I believe that is at 37 PSI, however those can be of very short duration that won't be displayed on the digital readout, I have not seen over about 20 PSI on the readout.
I will try to get some photos posted here later today.
<a href="http://s21.photobucket.com/albums/b258/OrbiTech/2001%20Dodge%20Ram/?action=view¤t=DCP_1816.jpg" target="_blank">
</a>
<a href="http://s21.photobucket.com/albums/b258/OrbiTech/2001%20Dodge%20Ram/?action=view¤t=DCP_1817.jpg" target="_blank">
</a>
<a href="http://s21.photobucket.com/albums/b258/OrbiTech/2001%20Dodge%20Ram/?action=view¤t=DCP_1818.jpg" target="_blank">
</a>
SHG
