Just Goy My SPA's installed, limits questions....
aFe Air Filters
Geno's Splash Stop
I have the Boost and the EGT set but where should I have the transmission and rearend temps limits set at?
The transmission probe is in the stock location in the Magtech pan.
Also what is normal and what is high readings.
I have done a search.
FYI, transmission is at 110 degrees and the rear end is 130 degrees cruis'n down the highway.
2001. 5 2500 QuadCab SLT, Auto, 3. 54 Anti-Spin Axle, 4X2, SWB, White/Tan, Stockland Camper, Interior kit, Debadged, Custom CUMMINS Logo Sticker, Gauges on their way with Pillar Mount, EZ Box on the Table, Front Spoiler, Sport Tail Lenses, Valentine One, Rancho Transmission upgrade, DunRite TC, VB Blueprinting, and the H3ll with the warranty, BOMBing shall commence.
www.ProwlerOnline.com
View my Cummins Sticker
I'm no auto transmission expert (hell, I nuked mine and then traded up to a stick), but I think I'd set the transmission warning at 200, maybe less. I seem to recall being told by a transmission guy that the goal is to keep the temp at or below 170 at all times, but that seems excessive.
As for rear end, the highest I've ever seen on my truck was 205, which was on the climb up the Grapevine going into or out of LA, weighing in around 20,000 lbs with my camper loaded and towing a car on the trailer. That's with a Mag-Hytech cover and Redline 90W-140 oil in the rear end.
Rob
2001. 5 RAM 3500 QC 4x4 ETH/DEE Silver/Agate, 4. 10, USGear OD, Rickson 19. 5 Wheels, DD EZ, DD3 Injectors, HX-40, Southbend Clutch, SPA Guages, Psychotty, Firestone Airbags, Hellwig Rear Swaybar, Torklift Superhitch & Camper Tiedowns, Mag-Hytec Diff Cover, DD 4" Exhaust, US Gear Exhaust Brake, etc.
Thanks for the come back, I have redline the rear and Mobil one in the transmission.
Grapevine is a bear.
thanks again
2001. 5 2500 QuadCab SLT, Auto, 3. 54 Anti-Spin Axle, 4X2, SWB, White/Tan, Stockland Camper, Interior kit, Debadged, Custom CUMMINS Logo Sticker, SPA Gauges Pillar Mount, Magtech transmission pan and rearend cover, Front Spoiler, Sport Tail Lenses, Valentine One, Rancho Transmission upgrade, DunRite TC, VB Blueprinting, and the H3ll with the warranty, BOMBing shall commence.
I have my trans. temp. warning light set for 270 deg. F. (I have the sender in the "hot" replacement cooler line). If I still had it in my Mag-Hytec trans. pan I would set it at about 200-210 deg. F. (using Amsoil synthetic Universal ATF+4... Mag-Hytec DD trans. pan)
I have initially set my rear end temp. warning light at 250 deg. F. (using Amsoil synthetic Series 2000 75W-90 gear oil... Mag-Hytec diff. cover).
Hey Rob, I was a LONG TIME user of Red Line synthetics... don't you mean 80W-140? (instead of 90W-140) I tried their 75W-140NS gear oil... there is NO friction modifier until you add it! (BTW, NS = No Spin)
John Treibel
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps and accs. , Mag-Hytec diff. cover & DD trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, Jordan Research Ultima 2020 trailer brake controller, SPA gauges (3), Dynamat, '00 Sport grille and headlights/PIAA Super White bulbs, "special" Brite-Box, PIAA Dual Sport 900 aux. lights, BD exh. brake, Amsoil Dual Remote Bypass w. trick billet block adapter and Aeroquip Teflon-s/s hoses, Optima Yellow Tops, DD3s and DD TTPM, Aeroquip AQP s/s fuel hoses, tricked out Cummins valve cover, tricked out Banks High-Ram and 14 cm2 (wastegated) turbine housing, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , DTT 93% TC, DTT custom tuned VB, BD modified trans. front pump (enhanced by DTT), Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
COMING ATTRACTIONS: break out those sun glasses! Plus, BLACKOUT gets a "BIG GULP"
NRA Life (Patron) member
[This message has been edited by John (edited 05-14-2001). ]
