Details here: TDR Privileges
This is what I am going to put in mine as it just went belly up, I like the fact that it is brass in stead of plastic that way if you spring a leak it can be repaired by a good radiator shop. Also brass tends to last longer then plastic. You lose a little bit of cooling efficancy with the brass would be the only downside.
Ended up going to Napa. They had a Rad. in stock for just over $200. It may not be the worlds best but it got me back on the road. I would like to thank every one for the help.
