Was changing the oil in my truck today when I noticed that the oil was kind of slow coming out. So, I stuck my finger in the oil drain and felt something over the hole. I moved it away to let the oil drain and immediatly went to the crank dampner. Took a pry bar and moved the crank back and forth a good 3/8". 226,000 on the truck. So, it looks as though the thrust bearing has fallen out and into the oil pan. Since I only drive the truck about 5 miles a day now, hopefully it will hold off until the first of the year. Im gonna try and pull the oil pan without taking the engine out. Will be going back in with new rod and main bearings as well. Hopefully this is all the damage that it has done. I have no idea how long it has been this way since it never reared its ugly head until now.
So, if you havent checked your crank end play. Do it as soon as you can. Apparently, the earlier 12v versions had a 3 piece thrust washer. The thrust washer apparently locked into the main bearing. I have been told the newer version is a half round solid unit with the #4 main bearing.
