Originally posted by Bigsaint
I was doing great on my first oil change with Baby Huey, loosened the drain plug and managed to get that tight factory installed filter off without a drip. Pulled a sample about mid-way for analysis and thought. . okay, enough is enough. . let me remove the drain plug and speed up the process ( the oil was flowing very nicely into one of those Wally world plastic oil catch/transport type containers). It's was as if the heavens above opened up... a huge flow of oil gushed out as I watched like a deer in the headlights as the oil flow quickly over ran the puny oriface of the catch pan and poured onto my driveway. I was completely helpless for that moment. The stain remains as a testimonial to my courage and stupidity, LOL.
Don't try this at home
Scott W.
Whoa!!
Exact same thing here,, was doing my first oil change on my truck,, I put a 12qt pan underneath the truck,, and lossened the drain plug, watched the oil trickle out,, un-srewed it a little more,,, then a little more,, Lookin' good,, just a wee bit mor... WHOOOSHHHH,, HOLY OIL SPILLS BATMAN,,
NOAH,, GET IN THE ARK, the Flood is a commin',,
I watched with an expression similar to Scotts as the oil quickly started overflowing the pan,, I couldn't figure what was up! then BAM!!, it hit me, OPEN THE VENT PORT YA NUT! So there I was, underneath my 2wd 3500 twisting, turning and jerking as fast as I could to open the little yellow vent port on the side of the oil catch pan,, Those things are sure hard to open when ya got oil runnin' all over 'em. I got about 8-9 qts in the catch can, and the rest I used on our driveway,, just to make the EPA Mad,, LOL.
I did manage to get about 11. 5 qts back in the motor. I used the other ~. 5 qt to make sure the outside of the motor was "Well Lubricated". (That's what happens when you decide to change your oil right when the sun is setting, and you spend 30 minutes using kitty litter to "hopefully" pick up some of the oil. )
I'm a klutz, and I'm glad I don't have to work on a D-Max or a POSD, I mean, a PSD.
Merrick Cummings Jr
