Engine/Transmission (1998.5 - 2002) Just one more
2nd Gen Non-Engine/Transmission My DMAX & PSD Story!
Engine/Transmission (1994 - 1998) enough power out of a 12v
Well I got Briar Hopper's fuel pressure gauge and checked the pressures and sure enough I've got problems according to what I've read. Now the question... Do I get a new one from Cummins or a different one? What's yall's thought on this? Also, I hardly ever go WOT, is there anyway to tell if the VP44 is damaged?
Idle - 11psi
Cruise - 10 psi
Accelerating - 8 - 6 psi
WOT - 0
Steve
I'd would replace the pump. Not worth the chance of ruining a VP44 pump. If you're out of warranty get the one from Cummins. It will cost around 149. 00. I don't have the latest part number, but I'm sure someone will chime in here. Also, if you do a search, you'll find the latest part number.
Charles
Cummins, Rainman
Definetly, definetly. Just had my lift pump replaced $145. 00.
Second what fj40charles said.
Have a good 4th. :D
I replaced my lift pump with the 15# carter and bought a 7# Carter for a pusher pump back by the tank. I also have a 30 micron filter to keep the pumps clean. so far I have 12-13 idle, 10-12 cruise, and no less than 8 WOT.
been doing great for several months now.
Got the kits over at jannetty racing
