K&N Air Filters
Anyone ever had Cummins do your warranty work?
Need opinion... Extra Fog lights
Blu-meanie
I see a lot of K&N filters in the signatures. Is that with or without the Psychotty housing? What is the EGT reduction with just the filter? #ad
2001 2500 Quadcab, 155" WB, Bright Blue, 6 spd, 410 posi, heated leather (for us older types).
Gary. . Both with and without... most guys would say Psychotty if they had it. .
as far as egt's you will hear 150 to 250 touted with Psychotty. . without- minor #'s but good spool up. . the filter that goes in the unit is # RE0880 K&N.
BTW on 4/7 we are getting together at Brandons in Modesto come on down. . your a local #ad
there will be 20/40 [or more it looks like]trucks and you can see all the goodies that we play with
[This message has been edited by willyslover (edited 03-26-2001). ]
I just put in a K&N filter prior to a DD stage 2 injector install(as per their recomendations)
EGT's seem only about 100 degrees higher at WOT with the DD'2s and the K&N, but I didn't try the new injectors with the stock filter so I have no 'degrees' to report on that.
Y2K Black 3500 ISB 4x4, 4:10 LSD,Auto,QC,SLT Laramie,"EZ",DTT VB,DD2's,LB, Polished Stull Billet Grill & Fog inserts, Chrome Smitty-Built Step Rails, Mopar Chrome-Tipped Mud Flaps, A-Pillar mounted West-Tach Turbo/Pyro/Trans Temp gauges,Rancho 9000's set at '1',Diamond Plated Tool Box, OEM U. R. Bedliner + other stuff.
Fact:The First Fords' had 'DODGE' Engines! The new PSD's need them!
K&N filters are a very divisive subject around the old TDR board. I won't post a pro-paper or pro-cotton opinion. I will warn you however, that for a LOT of owners here, a replacement aftermarket air filter was the first small step that culminated in $erious BOMBing addiction. Choose wisely and let the fun begin.
1999 White SLT Dually Auto 4:10 Posi. NOT BOMBED... ... ... ... (very much) 28,000 miles
TOPFUEL: Too late. I already have gauges, sissy bars, mudflaps and am looking at the $eriou$ stuff. You can never have enough goodies for your toys.
You can always remove the foam part of the stock filter and glue it a couple of places to the bottom of your K&N to help with dust. This is what I'm going to do this summer when the dust from our new home building lots gets too bad.
