Archived Kaboom
Archived Truck won't start
Archived No Tail Lights everything else works
Josparkz
I can't say my truck quit without warning. I had a little warning. Very little.
Tuesday afternoon I noticed I was getting a little whining kind of noise. It sounded sort of like my exhaust brake. I was pulling a trailer and had just come through from the car wash so I wasn't too alarmed.
Last night I went out a little, maybe 20 miles, and I'm starting to hear this noise again, sometimes. I get to playing to see which gear it's in, whether it is under load, etc. I see it seems to only happen with the overdrive locked out. Hmm. Maybe I got a third gear noise, I thought.
I checked my tires, and fluids today. Found nothing amiss.
Went to town, about 2 miles. I'm heading home and make an easy left turn from a stop. I feel/hear a big snap, and I've got a hellacious racket going on. I thought I had snapped a driveline and was dragging it.
I get through the intersection and pull over on the side of this overpass I'm heading for and get out. No drivelines hanging, motor running fine in park. I put it in D and get going, real slow. All kinds of banging noises and the truck doesn't hardly want to go. I try reverse, same deal.
I'm wondering if my air locker failed and it's something like that. I start shifting the transfer case, I seem to have all the functions. I put it back into 2Hi and I notice that I'm getting all this gear crash shifting between gears (like when your linkage is off), and it doesn't really want to go. I guess this kind of rules out a grenaded locker then, eh?
So I put it into 4 Lo and get going real slow. It seemed to make the least amount of noise and went the best. I was really wanting to get off the overpass by now, and didn't live but maybe a 1/4 mile. I figured what ever was done was done so I limped it home.
Crawled underneath it, couldn't see anything amiss. The transmission fluid smelled maybe a little burned on the dipstick.
It was about dark by then, so I didn't pursue it.
I'm still trying to figure if it would be the transfer case or the transmission. (this is where a divorced transfer case would be real handy).
I guess I'm going to start sticking a magnet into oil holes in things first, see if I can find some shrapnel in there. In case I don't, does this scenario sound (unfortunately) familiar to anyone?
I sure like to figure out what the culprit is before I either start jacking and blocking and dropping drivelines, or pulling off oilpans.
Either way, it had that REAL expensive sound to it.
I was going to suggest a broken flex plate, but since it actually moves, that's possibly ruled out.
Sounds like something internal to the auto transmission. The question is what could it be? Maybe you should drop pan and look for clues (chunks of metal or parts).
Good luck and hang in there.
John L.
The rear pinion gear seems to have lost in integrity, causing considerable damage to the ring gear.
The question now is why. Was it a failure of the locker , bearing failure, or what?
