Engine/Transmission (1994 - 1998) KDP Damage(part 2)
Engine/Transmission (1994 - 1998) TPS Maintenance
It's Alive :D Oo.
I finally got everything back together and I got the truck running about 2:00 today. Runs real good, I set the timing about 14. 5-15*; I could not get it to hold perfectly when I tightened the nut.
Some of the harder things I run into were
-Oil pan gasket kept wanting to slide off when I put the housing on, string didn't help much
-Lift pump(a pain)
-Two nuts on backside of inj. pump
-Setting timing pin(didn't bother) I could not get my hands/tools in there.
There may be more I'll think of later.
I was kinda worried about pulling the cam, but it was easy :cool:
Here are some of the parts I used and Cummins part numbers
-Gear housing 3936256
- Gear housing gasket 3938156
- Dowel pin 3900257
- Oil pan gasket 3959052
- Lift pump gasket(2) 3939258
- Gear cover gasket 3918673
- Timing pin oring 3913994
- Pump gear lock washer 3920922
- inj pump to gear housing oring 3969698
- Vac pump/power str pump gasket 3008400
Steven
