Before tackling the job, if I use the KDP jig and drill the gear cover of my 99 24V (built 11/98, possibly a KDP candidate), will I be able to see if the actual pin is still properly seated in its bore. I realize if you drill and hit something, it most likely is the pin half way out. But if you drill and hit nothing, am I to assume the pin is still in there, or is it reasonable to assume maybe it fell out but didn't cause any damage (yet). Just wondering if you can shine a very small light (fiberoptic) in there and see anything but a black abyss. Otherwise, I'll use the KDP jig fix and remove the cover anyway to make sure its still there (plus give it a little tap or two).
PS: I figured if anyone would know this it would be the 12V forum. Thanks.
