(I'm making a couple edits here after Woodenhead reminded me of a few things. Thanks Mike - it's been so long since I actually had the jig in my posession that I forgot some details)
A heads up for those who have recently or will soon be doing the KDP jig work on their trucks...
One of our members who just used the Northeast Jig found that the kit included only 3/4" long screws with the kit, and not the required 1" long screws. I'm not sure at what point the 1" screws were used up, but some may have mistakenly used the 3/4" screws, making the repair useless.
For all those using the jigs out there, please make sure you use the correct tapered-head 1/4" x 20 x 1" long screws. If you have already used the wrong screws, you should probably replace them as soon as possible.
The 3/4" screws are provide in case the 1" screws will not thread in all the way (indicating that the dowel pin may already be part way out). The 3/4" screws will at least plug the hole until the time becomes available to disassemble the cover to push the pin back in.
Some don't understand that the screw installed with this repair is supposed to extend PAST the dowel pin to prevent it from coming out. Some thought it worked as a set screw to hold the pin. If the screw is too short it will do nothing to keep the pin in.
Sincerely,
Blake
NE Jigkeeper
Sincerely,
Blake
NE Jigkeeper
