Details here: TDR Privileges
Has anyone used the KDP kit TST offers? They list it as 94-99, but I was thinking it would work on 1st gen also. Curious if it has everything in it needed to do the job, (seal kit, gasket, RTV... . ) Any comments would be appreciated. Thanks.
The 94-9 gear case is flush with the end of the pin. The surface of the case is flat from the nearby bolt hole to the pin area so a tab can go over it easily. The first gen case is raised up around the pin so a tab would have to have a big step in it to work.
