When I joined this forum, right after I bought my truck, the KDP was one of the first things that caught my eye. Naturally, with a name like 'Killer Dowel Pin', it's an issue that gets one's attention. But reading around in the archives, it seemed like it was just a 12V problem (at least predominantly), so my fears slept.
But last week, I noticed some oil spots on the ground. I think it was from the fuel dripping down where I'd opened the fuel drain earlier in the day, but it got me looking around. Good lord, there was a bunch of oil on the front/bottom of that engine! The KDP started coming back to mind. Some Simple Green took care of all that oil (looks like it was all from the breather), but I noticed what looked like a crack in the timing case, low behind the damper. Aaagh! After panic went its way, I noticed a similar mark on the driver's side--both just casting marks, and some research showed the case usually cracks behind the fan hub bracket, anyway.
All this was so unnerving, however, I decided I should take care of the Pin, just in case, so I ordered the tab kit from TST.
Started working on it late this morning. Their instructions (very good ones, for the most part) had me removing the fan and shroud at the same time, by unbolting the fan pulley bracket. Directions I'd found here said it was easier to knock the fan hub off first, so I tried that. For the life of me, I couldn't get the bloody nut off. Even with a drift punch and some good whacks with the hammer, I couldn't get it off. Couldn't keep the belt from slipping, even with increased tension.
So I ended up following the directions. That fan is bloody heavy! My back is quite angry with me, and I imagine it will be for a while.
But I digress. Anyway, I got the cover off to find the tab won't work--there's a boss around the pin. Can't really tell if it's the new design or not, but the pin's still seated. I did what the old Cummins memo I read recommended--use a punch in the bore to make a 'dent'/hardened area, and put Locktite around the pin face. Hopefully, if it's not the new design, that will secure it. At least I got the crank seal changed.
Got it all put back together (in the dark, and my flashlight died, too--had to hotwire a spare tractor light off one of the batteries so I could see), and the fan didn't get any lighter.
Seem to run okay, and I didn't have any parts left over at the end (don't you hate that
), but I have one concern. When I first put the fan back on, it would spin freely. When I was done buttoning everything up, there was definite resistance, as if the hub had engaged. Fan was running as soon as I started her up, too.
It was in the upper 60s/low 70s, and I didn't think the fan should be running right off.
Is this normal, or did I whack something I shouldn't have? Don't think I let any of the fluid leak out, so I can't think what else I could have done. Any ideas?
Oh, and all you guys that went before--thanks for all the tips and advice.
--Ty
--Ty
