Engine/Transmission (1994 - 1998) KDP Pin
2nd Gen Non-Engine/Transmission Loss of vaccum for brakes
Engine/Transmission (1998.5 - 2002) BD boost fooler kit OK alone?
KDP dowel pin
I took the timing cover off to fix the pin
the pin had moved a little drove it back in to put A tab dehind the closet bolt to the pin removed the bolt did not sean tight
does anyone know the torque of the bolt that would hold the tab.
Also what size bolts behind the timing gear & torque of said bolts
Use red loctite on all the gear case bolts including the one that holds the KDP tab. If one of them falls out it really does damage. You should replace the one for the tab with a longer bolt. 18 ft/lbs for the bolts.
