Engine/Transmission (1994 - 1998) KDP Question
2nd Gen Non-Engine/Transmission Trailer blowing fuses
Engine/Transmission (1998.5 - 2002) EDGE COMP/DRAG COMP question
I want to do the KDP fix on a 94 that I just purchased. It is CPL 1815. I have purchased a new front seal, the gasket, the longer capscrew (3900631) and the lockingtab (3958017). While I am in there I will torque the 4 oil pump bolts, the 2 cam plate retaining bolts, and any other timing case bolts. My question is, How many case bolts are there? I don't want to forget any and live to regret it. I would like to remove, clean, locktite and reinstall all of them or at least as many as possible at this stage of dissassembly. Thanks, John
Don't recall for sure, but I think there are 5 (?) case bolts behind the cover. I think I was only able to get to 3 of the inside case bolts. Been a while since I've been in there.
The bolts for the cover are several different lengths. I would lay them out on a bench to keep them in order.
IIRC, they are all (case and cover bolts) torqued to 18 ft/lbs.
If you Go to dodgeram.org click on (diesel) and follow the links for you truck yr. it will show pics of the process. There is probably pics etc here also if you look in the archives
