I took off my front cover tonight and discovered my KDP is resting peacefully where Cummins put it. However I cant really tell if I have the stepped or improved cover or not. I do know that I was planning on installing a tab... which up to this point has been described as a simple fender washer or a custom made shape out of steel stock. In either case it looked like a flat piece.
After careful examination, I dont think there is anyway I can install a tab on mine... unless its stair stepped (not flat). From photos I've studied in the past, tabs look like they install under the nearby case bolt and extend over to cover the tab. The tabs in the photos (which I cant find tonight for some reason) appeared to be flat and they simply cover the KDP hole. But my hole end is raised above the surface the nearby bolt is up against... maybe 1/8 to 1/4 inch. So its impossible to use a flat tab in my case. I suspect if I had used the jig, I would have been drilling through alot more metal than usual.
Does this mean I have the improved case? I've seen photos of the stepped hole improved design from the backside... but none from the front so I have no idea what I'm seeing. My pin is recessed in the hole maybe 1/4" and I didn't feel like tapping it and checking with a dial indicator for movement tonight.
I wish I had access to the camera so I could post what I see. I'll try that tomorrow if nobody knows
PS: Is the some kind of slinger ring I should put on the crank stub before the new seal is installed? I dont have one on there now. And should I use a cover gasket or grey RTV? All I could see was grey RTV and no gasket on mine... it literally popped right off all at once. I prefer gaskets.
Man its late... I think I'll get to sleep now
