If you search around on here you can find a part # for the tab from cummins. It cost a couple of $$ - way cheaper than what Geno's charges. You can also drill a hole in the aluminum and use a set screw and red lock tite. It will be a tight fit with the radiator and all, but I would rather cuss a little at the tight spot then drop $70 for $10 worth of material.
