Keeping the fog lights on
Fuel heater filter help
Reprogram needed if doing a gear change
Anybody know the trick to keep the factory fog lights on when you turn your brights on?. I heard awhile back it was a simple jumper wire install in the fuse box.
It is in the main fuse box under the hood on the drivers side. There was an article on that in one of the TDR Magazines. It told which relay to pull and what two pins to jump. Without going out and looking at my truck I can't tell you which relay to pull (it may be marked on the cover) once the relay is out you need to jump the two spade sockets that correspond to the two larger termanals on the Relay you pulled out. I can go out and look in the AM I just don't want to wake the guests at the motel by closing the hood right now.
2001 2500 QC 4X2 Flame Red Clear Coat
Magalia Ram
[This message has been edited by M_Pulling (edited 04-16-2001). ]
EMDDIESEL,
<FONT FACE=COMIC SANS>Try this http://dodgeram.org/tech/mods/electric/headlight.htm .
I think this is what you're looking for. I did this modification to mine and it works great. </FONT> #ad
Dennis D. Tway
"RATTLIN" *1999 2500 SPORT QUAD CAB* "RAM"
IntenseBlue/SB/Cummins/4x2/auto/3. 54AS/4whlABS/Camper&TowPkg/
Keyless/Leather/TravelConGrp/SecuritySys/6spkrCD*Cass/Strngwhlcntrls/
WestinTubeSteps/SportMastersSoftTonneau/15k RBW 5th-WheelHitch/26'Nomad 5er (looking for a bigger one) and a way to take my HARLEY too!
-- email address removed -- or -- email address removed --
It's easy to do. Take the fuse out. Two 1/4" spade connectors, an inch and a half of wire and you are good to go.
1999 Dodge Ram 3500 Quad Cab 2wd; 5 spd; 4:10 LSD rear; Mag-Hytec differential cover; US Gear EGT and Boost gauges. Stewart Warner Fuel Pressure Guage with dual senders. Amsoil foam air filter and synthetics from nose to tail.
Cummins Power, don't leave home without it
It's easy to do. Take the fuse out. Two 1/4" spade connectors, an inch and a half of 14 gauge wire and you are good to go.
